Bilstein vs KYB
Posted: Wed Dec 15, 2010 10:36 am
by Elcapitan
Hey guys
Before you ask, yes, I have already read alot of posts on suspensions before deciding to post my q's. I know alot of people choose the KYB- AGXs or GR2s but I have heard no mention of the Bilstein shocks. Which is the better and why? Also what are the part numbers for a good set of bilstein shocks? Is there a prefered coil for either or a general multi purpose setup ( by that I dont mean for track use, just daily driver with umph for when i need it). preferably cheap spares coz this girl aint cheap...women!!. btw how often should the suspension(shocks & struts) be replaced?
Lastly, any one has a stash of cash that they arent using so I can finance my projects
Re: Bilstein vs KYB
Posted: Fri Dec 17, 2010 5:37 am
KYB actually makes the housings for the Bilstein's that are used on Subarus.
I honestly don't think you'll readily find a set of Bilstein struts that are made for our Legacies. I think others have used Impreza/WRX stuff. The Bilsteins can be inverted and be a little beefier for rally/heavier duty use.
If it's a daily driver....I'd just stick with KYB.
Re: Bilstein vs KYB
Posted: Fri Dec 17, 2010 7:16 am
by Elcapitan
Good to know. Problem is there is only one specialist shop here that has/ deals with the KYBs and you do pay for that exclusivity...Approximately 1000 USD!!! Is that normal pricing or can I try purchase separately and have them do the installation?
Re: Bilstein vs KYB
Posted: Fri Dec 17, 2010 8:50 pm
by SubyFusion
Where do you live? I got mine off the internet! like $250.00 total
Re: Bilstein vs KYB
Posted: Fri Dec 17, 2010 9:59 pm
by evolutionmovement
tirerack.com. Not being easy on my cars, a set of GR2s lasted me about 130k miles, but even when they went bad, they stiffened more, rather than floated. Front OEM struts were blown out when I bought the car with 107k.
Re: Bilstein vs KYB
Posted: Fri Dec 17, 2010 11:27 pm
by SubyFusion
I got mine on amazon with free shipping its cheaper then tirerack.com.
Re: Bilstein vs KYB
Posted: Sat Dec 18, 2010 4:25 am
by beatersubi
evolutionmovement wrote:tirerack.com. Not being easy on my cars, a set of GR2s lasted me about 130k miles, but even when they went bad, they stiffened more, rather than floated. Front OEM struts were blown out when I bought the car with 107k.
Good thing KYBs have a lifetime warranty.
Re: Bilstein vs KYB
Posted: Mon Dec 20, 2010 7:39 am
by Elcapitan
SubyFusion wrote:Where do you live? I got mine off the internet! like $250.00 total
Really? Which part of the internet? I live in NBI, Kenya. If i got em for that price that would be great! btw what do we have on our cars? Shock & springs /struts/ ?
Re: Bilstein vs KYB
Posted: Wed Dec 22, 2010 6:16 pm
The stock setup uses struts and springs in the front and rear.
Re: Bilstein vs KYB
Posted: Sun Dec 26, 2010 6:00 am
by SubaruFred
Elcapitan wrote:SubyFusion wrote:Where do you live? I got mine off the internet! like $250.00 total
Try
www.discountautoshocks.com I got 4 new KYB GR2s for $230 from them. Obviously you'll pay a lot more shipping but it might be worth a call.
Re: Bilstein vs KYB
Posted: Tue Jan 04, 2011 8:20 am
by Elcapitan
Thank you mate. I'll check on them and let you know. btw that does not include springs right? If not is there a specific spring to look out for?
Re: Bilstein vs KYB
Posted: Tue Jan 04, 2011 8:42 am
by Elcapitan
Ok so slight problem. Whenever I select the model ie legacy, I get submodel options of L, L S, L Si and sport!! Mine is an RS. Which category does that fall under?
Lastly is there a Part number coz all what I found stated gr2/ excel G. Is that the same part? Really confused here
Re: Bilstein vs KYB
Posted: Tue Jan 04, 2011 5:46 pm
by SubaruFred
Springs are not included, just a replacement strut assembly. You'll need springs, rubber perches, top spring perch and top mount to make a loaded strut assy. There may be others but the only springs I know will fit are Legacy springs from Subaru. AFAIK all models use the same struts but different spring rates for wagon, sedan or turbo.
According to KYB, GR2 and Excel G are the same struts painted different colors. GR2's are silver and being phased out in favor of black Excel G's. To get part numbers I'd need to know more about your suby. Year, model, engine, etc. I'm sure that discountautoshocks can help with that. Good luck.
Re: Bilstein vs KYB
Posted: Thu Jan 06, 2011 8:03 am
by Elcapitan
SubaruFred wrote:Springs are not included, just a replacement strut assembly. You'll need springs, rubber perches, top spring perch and top mount to make a loaded strut assy. There may be others but the only springs I know will fit are Legacy springs from Subaru. AFAIK all models use the same struts but different spring rates for wagon, sedan or turbo.
Thankx, you got me to finally add my car to my sig. I'm sure that'll make it easier to get help from you guys. What do you figure the approximate value of the complete setup would be. It might end up being close to the price I was quoted for here in which case it would be easier to buy local rather than try to import for myself ryt?
Re: Bilstein vs KYB
Posted: Thu Jan 06, 2011 7:03 pm
by SubaruFred
Unless you have air suspension you should be able to use your old springs, etc. All you should need are new struts and mounts. That should cost under $400 plus shipping. If you need loaded strut assemblies, your best bet is to buy used struts and replace the struts and mounts (if necessary). FWIW, I just replaced my air suspension with new GR/2s and junkyard springs, etc. for under $500. I'm using the old mounts and new ones would have cost $150.
Re: Bilstein vs KYB
Posted: Mon Aug 25, 2014 7:40 pm
by Elcapitan
This is too funny. Its been so long since I was on here, that I came across this while doing some research on springs. Read the first post and thought "this sounds like the kind of funny guy that I could get along with"
7 replies down I read the name and realize that this was my question waay back then :-0 !!
funny right. Thank you to all who commented and pointed me in the right direction.
Re: Bilstein vs KYB
Posted: Tue Aug 26, 2014 5:58 pm
So what struts did you end up going with?
