Size of LEDs for the cluster
Weston_Duyck
Im wanting to put red LEDs in, instead of the stock green and im wondering what size i should get for that.
93 Winestone Subaru Legacy L AWD-BROKEN
86 White Toyota 4Runner SR5 4x4
---Girls love it when I hit it sideways(It's a DRIFT thing)---
Re: Size of LEDs for the cluster
The bulbs are white, the 'condom' covering them are green. Thus, easy to change over to red.
'11 WRX Limited
'94 TW | R.I.P.
martimus919
The gauges them selves have green tinting as well, if you shine a light through them they look mint colored. I'm wanting to do a plain LED white, just nice and simple and clean look... I haven't gotten anywhere yet, I don't like mint.
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
bmxkelowna
4 red - #74
2 red - #194
didn't remove any of the white backing on the cluster just plug in LEDS and re-install cluster
2 red - #194
That looks pretty good. What about the green tinting, did you do anything with that?
holy red cluster bat man !!
bmxkelowna
did nothing with the tinting the red leds were more then enough
the two bigger #194's have 5 leds and look like this
and the four smaller #74 leds look like this
What do the 2 bigger ones go to? Like if I want to do the tack and speedo blue and the rest red what would I have to do?
92 Turbo Legacy 2.2L
96 Explorer 4.0L
96 Explorer 4.0L
The two bigger ones go at the top of the tach and speedo and theres not really a way to light each gauge individually due to placement of lights. The smaller ones go on both sides of the tach and speedo kinda like, s b s s b s where s=smaller and b=bigger and there aren't really any dividers either.
Danny
Weston_Duyck
Where did you buy the LEDs at?
bmxkelowna
Weston_Duyck
Ok I found the smaller ones but I'm having trouble finding the bigger one. Does it matter which type goes in as long as it's 194
bmxkelowna
If you put blue ones in do you think I'll have to remove the green overlay thing?
94 legacy gt turbo
pics! http://bbs.legacycentral.org/viewtopic.php?f=9&t=45358
bmxkelowna
from what i remember a while ago some one tried the blue ones and there were not as bright so yes, i would suggest removing the green film
Awesome, thanks for the info! I've been wanting to do this, I hate the green, and red's easier on your eyes.
And Subie, it takes longer for your eyes to adjust at night from the blue light back to darkness, I would not recommend it, red will be the easiest on your eyes. But it's up to you, I can't see it being a huge issue, I know even the green bothers me though since I'm used to red.
Weston_Duyck
Thanks! I found all the ones I need and I'm going to order them and they shall be lighting up soon.
Yeah....if I swapped I'd go all red.
Well i did a cluster mod to my car a LOONG time ago with blue bulbs.
All i did was take standard 194's and painted them with glass paint.
I did nothing reguarding prizm moding, just the grean domes off the lamps.
It does work but its bunk when you figure out that there are 2 more bulbs that need replacing.....
So im going to do this mod with blue LED's to see my results.
i wanna white but i'm not sure does the beatiful..red is very nice.how this led installed..need to remove the whole console?
Yes you need to remove the entire cluster and lots of other rando plastic stuffs in and around it.
OK. Thanks
If I was going to do orange/amber L.E.D.s would the green tint stuff be a problem? I've seen orange/amber gauges before and, personally, I like it the most with red being a close second.
Danny
If anyone has ever done blue please post pics!
94 legacy gt turbo
I am just curious cause I'm trying to do this, is there anyone who could give me two part numbers? I want to try the blue or maybe the red but the bulbs I found I'm not sure are the right ones so I don't want to order the wrong ones can someone help me out?? And maybe post a few pictures on how to separate a cluster the proper way cause I'm a big guy and just don't want to end up ripping it apart and breaking shit. Any help would be greatly appreciated.
