Anyone know what these connectors are for??
Posted: Tue Dec 21, 2010 9:45 pm
by LegacyT
The two connectors coming out of the headlight harness on the passenger side. Its a turbo sedan btw. Foglight harness???
Re: Anyone know what these connectors are for??
Posted: Wed Dec 22, 2010 10:20 am
by Danny-G
I have the same plugs on my '93 n/a and if I remember correctly Legacy777(Josh) said its th sub fan short connector. Heres the link to my thread about it http://bbs.legacycentral.org/viewtopic.php?f=19&t=44270
Posted: Thu Dec 23, 2010 5:52 pm
by Shaggy
I have them on my 90 and was gonna ask the same question about a week ago but never got to it lol
Posted: Sun Jan 02, 2011 3:01 am
by criticalm@ss
fogs??
Posted: Sun Jan 02, 2011 11:26 pm
They should be the sub fan short connectors.
Do both fans turn on together when the ECU kicks the fan on, or does only one fan turn on? If only one fan turns on, plug those connectors together and see if both fans turn on.
Posted: Mon Jan 03, 2011 6:16 am
by Danny-G
Would connecting the connectors help with my fan problem at all?
Posted: Mon Jan 03, 2011 7:02 pm
Danny-G wrote:Would connecting the connectors help with my fan problem at all?
Can you refresh my memory about the specifics of your fan problem.
Posted: Mon Jan 03, 2011 7:57 pm
by Danny-G
The left fan doesn't come on when the right does and the fuse under the hood blew in abot five seconds after I replaced it so I'm currently getting by with a thirty amp fuse even though I shouldn't do that.
Posted: Tue Jan 04, 2011 7:19 pm
Umm, I think connecting it should get both fans to come on.....as for it fixing the other problem, I'm not sure about that.
Posted: Wed Jan 12, 2011 7:29 pm
by __TT__
so what is the point of them? connect them if your in a hot climate? or just for testing?
Posted: Wed Jan 12, 2011 7:40 pm
If you don't have AC, then you only have one fan. Most of all the cars I have seen have come with AC. I believe the connector was a way to integrate two different wiring setups together to acheive the desired output, ie both fans coming on.
With the newer cars, that control is all based in the computer.
It's actually pretty neat, our legacies have a decent amount of electrical wiring "logic" built in which allows you to intercept/modify signals if you get the wiring right. The newer cars, all the switching and logic is built into the ECU and requires reprogramming.
