WTB 94 engine Wiring Harness TURBO
Posted: Sun Dec 26, 2010 3:44 pm
by Weazel240
Lookin to buy an engine wiring harness off a Turbo 94(91-94 same?)
From ECU to engine is all i need. PM me if u got one thanks!
22T
Re: WTB 94 engine Wiring Harness
Posted: Sun Dec 26, 2010 5:54 pm
by cj91legss
Try to be alittle more specific. Do you want a wiring harness for a turbo legacy or an n/a?
Re: WTB 94 engine Wiring Harness TURBO
Posted: Sun Dec 26, 2010 6:14 pm
by Weazel240
EDITED, sorry thought i had it on there.
Posted: Sun Dec 26, 2010 8:17 pm
by cj91legss
no problem, just helpin out
Posted: Sat Jan 01, 2011 10:31 pm
by Weazel240
bump
Posted: Sun Jan 02, 2011 12:36 am
by mike-tracy
FYI 91 has different plugs than the 92-94's.
Posted: Wed Feb 16, 2011 5:12 am
by Weazel240
Bumppp 91 or 92-94.
Need it for a 20g project.
Posted: Tue Feb 22, 2011 4:10 am
by Weazel240
bummp
Posted: Tue Feb 22, 2011 9:06 pm
by Splinter
How much are you offering? It's quite a bit of work to remove.
Posted: Wed Feb 23, 2011 12:40 am
by tahiti350
we have one at the wrecking yard I work at, but it has 2 injectors that aren't getting a driver signal... Boss want to get it running right before he dicides what to do with it...
Posted: Thu Feb 24, 2011 5:09 am
by Weazel240
I dunno what to offer honestly.
I have a local seller but he askin 150. Im tryin to get the better deal of course.
Posted: Sat Feb 26, 2011 2:03 am
by Rubasu
good luck on the better deal. i pulled one for no reason and its not fun at all. But what kind or car is it cause the n/a harness is the same to the same pin outs, with the exception of the year of the plugs and then the engine harness can be changed.
Posted: Tue Mar 22, 2011 8:46 pm
by Weazel240
bunmmmp
Posted: Tue Mar 22, 2011 10:41 pm
by 1wormsway
Have injector and sensor harness off 93 EJ22t. This has plugs at the inner fender well next to the battery and extends to the sensors and injectors on engine. Intake manifold has to be removed in order to replace. Not as bad as it sounds , but must not have a heavy hand when disconnecting and reaattaching vacuum lines and intake components. Will take $50 and you arrange shipping Cheers,J
Posted: Fri Mar 25, 2011 3:09 am
by Weazel240
PMd bump
Posted: Tue Mar 29, 2011 3:50 am
by Weazel240
bump
Posted: Tue Mar 29, 2011 4:07 am
by 1wormsway
Are you looking for the injector harness and sensors harness that plugs in at the inner fender well behind the battery and extends to the engine / via under the intake manifold ? Have one off a 91 0r a 93 / $50 each.
Posted: Wed Mar 30, 2011 2:19 pm
by church207
i have a full 93 ss harness out in a box has a cupple wires that need to be fixed but its all there ecu to engine
