Ok, so I just got done with my EJ22T swap in my 91 legacy wagon. The car was originally a EJ22 n/a with a FWD transmission. The EJ22T came out of an AWD car. I swapped over the entire turbo wiring harness into the wagon, and had to make one connector work for the transmission. Now, for the question. I have no idea what this connector goes to for the car. It isn't in the n/a harness at all. Anyone know anything about this?
It goes into this part here, right in the hole that the n/a harness leaves open, and the wires all go to the rear of the car. But, the wires are all cut about 2 feet after the plug. What does this do? Would it keep the fuel pump from coming on now?
edit: fixed one of my problems already
