help with 06-07 lip.
Posted: Fri Jan 07, 2011 10:39 pm
by LookAsubie
Hey just wondering if someone could give me some specific details on how to get the ebay 06-07 lip to fit on my 92. I just started to try a little bit ago and it kinda looks like it wouldn't fit. But I know people have it on their 92's. I know you have to cut small chunks out to bend in the sides a little.
So please someone give me a nice good detailed description on how to do it. It would be greatly appreciated.
Thanks.
Re: help with 06-07 lip.
Posted: Sat Jan 08, 2011 12:03 pm
by LookAsubie
Bump!
Posted: Sun Jan 09, 2011 9:05 pm
by GClark
Ask mikeymeyagi, he has one.
Posted: Mon Jan 17, 2011 12:33 pm
by LookAsubie
Got it on finally.
Posted: Mon Jan 17, 2011 1:20 pm
by kimokalihi
Looks like you did a fine job sir. I messed mine up somehow and it bends up in the middle. Lame.
Posted: Mon Jan 17, 2011 4:58 pm
by 92.Legacy.SS
looks very clean.
just wondering how you got it to fit?
Posted: Mon Jan 17, 2011 5:06 pm
by kimokalihi
Easy. Just get a bunch of self tapping screws and bolt it on. Cut out a couple triangles from the corners to help it bend since the sides stick out a lot. Use a heat cut to help it bend nicely. Then trim the ends to fit the bumper.
Posted: Mon Jan 17, 2011 7:18 pm
by Florin1
Kimo, mine started to bend up as well right in the middle, so i made a bracket for it to straighten up again. Now it looks swell. ;-)
Posted: Mon Jan 17, 2011 9:13 pm
by LookAsubie
Thanks guys :) I just bought a bunch of 1/4 inch and 5/16 bolts, washers, and nuts to use, did you guys use the existing holes? I drilled new holes to get it to fit how I wanted it. Didn't use a single one of the existing holes. I didn't use a heat gun or anything either. Just cut triangles from the bends on each side and the trim the ends to match your bumper. I had 2 friends helping and a lift which helped a lot. Doing this by yourself would be a pain in the ass lol. It isn't perfect, but I'm very happy with it :)
Posted: Tue Jan 18, 2011 2:44 am
by Florin1
I used like 20 little self tapping screws, haha. Did it solo. :p
Posted: Tue Jan 18, 2011 2:46 am
by kimokalihi
Yup I do everything solo. No lift just a floor jack. None of the existing holes are in the right places to mount it properly to our bumpers.
Posted: Tue Jan 18, 2011 3:27 pm
by SiCkSTi04
Could you provide some pictures from under the car? or some install close up's
Posted: Mon Feb 06, 2012 7:54 pm
by chochocho
kimokalihi wrote:Easy. Just get a bunch of self tapping screws and bolt it on. Cut out a couple triangles from the corners to help it bend since the sides stick out a lot. Use a heat cut to help it bend nicely. Then trim the ends to fit the bumper.
any particular type of self tapping screws you went with? 1/2" length would work, right?
Posted: Tue Feb 07, 2012 12:22 am
by kimokalihi
1" black self tapping screws and I believe they came with the lip. I bought another lip from a different seller this time I think so we'll see what I get. Should be arriving any day now.
Posted: Tue Feb 07, 2012 1:02 am
by GClark
I just used dry wall screws :)
Posted: Tue Feb 07, 2012 1:09 am
by kimokalihi
It works. I used drywall screws to fit my gf's rear lip on her 2000 LX Civic. Worked excellent.
Posted: Tue Feb 07, 2012 4:44 am
by MikeyMeyagi
drywall screws work good for everything lol
