92 idle miss
Posted: Sun Jan 23, 2011 2:42 am
by turbo5711
I have a 90 legacy with a 92 motor n/a in it I have a miss at idle but runs good above 2000 rpm. I have checked all the sensors i have tried changing the plugs wires and even the injectors it is only happening on the passgeer side head but i am at wits end with it
Re: 92 idle miss
Posted: Sun Jan 23, 2011 6:03 am
by wtdash
Compression test?
Re: 92 idle miss
Posted: Sun Jan 23, 2011 11:26 pm
by jefferson
That was my thought too.
Re: 92 idle miss
Posted: Sun Jan 23, 2011 11:34 pm
by turbo5711
ok thanks ill try that test on it next
Re: 92 idle miss
Posted: Mon Jan 24, 2011 12:22 am
by SiCkSTi04
Is this an engine swap with the misfire results? or did you get the car this way. reason I ask if you swapped over the injectors as they are different. Also try doing an ohms test on the injectors, coil pack and spark plug wares. And if you're getting any trouble codes.
Re: 92 idle miss
Posted: Mon Jan 24, 2011 2:54 am
by turbo5711
it started after i had a timing belt slip it is 1 cyl not firing at all i am worried it is bent valve got i hope not ill check compression soon
Re: 92 idle miss
Posted: Mon Jan 24, 2011 5:27 am
by wtdash
The EJ22 was non-interference 'til '96-ish, so shouldn't have bent a valve, but are you 100% sure you have the T-belt on correctly? One tooth off or using the wrong mark on the Crank sprocket will cause similar issues.
Re: 92 idle miss
Posted: Mon Jan 24, 2011 7:45 am
by turbo5711
humm thanks for info ill check it tommorw
Re: 92 idle miss
Posted: Thu Jan 27, 2011 3:31 am
by turbo5711
well thanks for the info it was the timing it was a tooth off on passenger head all fixed runing very good now
Re: 92 idle miss
Posted: Thu Jan 27, 2011 4:09 am
by SiCkSTi04
Awesome to hear! Cheers!
