Accelerator/Throttle cable arrangement.
Posted: Fri Feb 04, 2011 11:06 am
So... I have a 91 Legacy Wagon (2.2. Non Turbo). I am currently in the process of replacing the head-gaskets, its a cheap car, and I enjoy learning and working on them so... anyway. I was removing the Throttle body and intake, I started disconnected blow-by hoses and such, and disconnected the gas lines on top of the engine (yes it sprayed a little), anyway... with the scent of fresh-gas in the air I began to feel, not so great... I freaked out and began disconnecting everything as fast as I could just to get it out of the way so I could leave the shop, not paying attention to how things are set up like I normally do. When it came to the throttle cable, I loosened the nut at the end of it, and just slid all the adjusters off until the top part of the engine was free... now the problem is, I don't know how to put this cable back on correctly. Theres a spring, a series of washers, a couple of quarter circle shaped things... Any help anyone? A detailed picture might work.
