Spring Clearance Sale
Posted: Fri Feb 11, 2011 7:34 pm
by jaybirde508
All Prices are Negtiable:
* (2) Link Plus ECU G1 / V10
Both units have been cleared from Link USA ,All options funtion
ANti LAg
Flat foot shift
2 Aux channels
Sequential injection
6 wire IAC board
Both come with all accessories to connect to laptop
USB cable, Serial Box, patch cord
500.00 Ea.
* (2) SAFC Apexi I
100.00
* (2) Tdo4 -13t
Minimal shaft play,comes with coolant & banjo bolts & washers
100.00
* (1) TD05-16 Front entry
Needs rebuild
50.00
* 520 cc STI S/F injectoers w/ fuel rails
return to stock 10K
150.00
More to come
Re: Spring Clearance Sale
Posted: Fri Feb 11, 2011 9:14 pm
by speedmaxx
What's the best u can do on a td04 And a safc? How much we talking shipped to my door?
Posted: Sat Feb 12, 2011 2:56 am
by Mattheww044
is the link a full standalone?
Posted: Sun Feb 13, 2011 1:23 am
by jaybirde508
Yes,
Link+ has been used in Subarus For years in Austraila & Nz check out some of the NZ sites giggle link Plus ,they are older ,But then again if ya want to spend 1500.00 for a G4 ,They work mint I have 2 others I run in R/C I just aint gonna use these two ,Very simple to tune I also Have a ton of start up maps for N/a's & turbos
This is Also a MAP system / speed density so you will not neeed your MAF leav it remove it I also Have a IAT ssendor that will drop into place of your MAf & pnP
I actually have a 4 plug ecu PnP harness I can toss in & I could make up a 3 plug harness if needed ,The N/a imprezas run the 3 plug as well Anywho I hope that clerifys things
This is a spring cleanning sale ,I got more goddies than I can remember,So items will be added as I find them
jay
Posted: Sun Feb 13, 2011 2:07 am
by Florin1
Where are you located?
Posted: Sun Feb 13, 2011 3:02 am
by Mattheww044
I might be interested in one of the Links. I am in the market for a standalone but I'm not sure which one I wanna get. been looking at the Adaptronic, but i just don't have $1100 sitting around. Do you just replace your stock ECU with the Link, tune, adjust, and ready to go? Don't know much about standalones but wanting to learn and get one. I have a JDM manifold and DOHC swap that Ill be buying soon as well
Posted: Mon Feb 14, 2011 8:24 pm
by beatersubi
What condition is the td05 in, other than needing a rebuild? Do you have any pics of it or, more specifically, the compressor wheel?
