WRX Rear seats in a 93 legacy sedan?
Posted: Sat Feb 12, 2011 1:09 am
by Weston_Duyck
So I've been wanting to make my interior look better and I found some rear seats. Will they fit somewhat easy or no?
Re: WRX Rear seats in a 93 legacy sedan?
Posted: Sat Feb 12, 2011 3:29 am
by kimokalihi
They fit quite easy. I don't know what years but I'm guessing 2002-2006 is a safe bet. I have 2002 in mine now. All I had to do to make them bolt in with OEM fitment is drill a hole in the middle mounting bracket on the bottom for the bolt to go through. The WRX bolt hole is way off from the legacy bolt hole. There's a picture or two of this in my build thread somewhere when I was installing them.
Posted: Sat Feb 12, 2011 9:06 pm
by subydaddy
Just make sure to aim high on the seat back, that way the seat bottom will fit right. After you take the seat out look at the stock bolt location for the seat back (the ones right next to either door). Well about 1-2 inches above those will be another bolt hole, that is where the wrx seats will bolt in.
Posted: Sat Feb 12, 2011 9:38 pm
by Weston_Duyck
Ok thanks for the information :)
