Issues with removing the transmission.
Posted: Sun Mar 13, 2011 2:07 am
by Weston_Duyck
So I need to get the CV apart from the auto tranny and I can't figure it out...help?
Re: Issues with removing the transmission.
Posted: Sun Mar 13, 2011 3:33 am
by Rubasu
Did u knock out the roll pin that holds the splines together?
Posted: Sun Mar 13, 2011 3:40 am
by Weston_Duyck
Ya I got the pins out and then I took the stut to hub mount bolts off and got it
just the other side is very stuck
Posted: Sun Mar 13, 2011 4:02 am
by Rubasu
Pb blaster, I love it!
Posted: Sun Mar 13, 2011 4:12 am
by Weston_Duyck
I've used liquid wrench, then broke my ratchet and then tried a impact wrench and still nothing
Posted: Mon Mar 14, 2011 2:07 am
by Rubasu
Try some elbow grease, but I think you can only get that in a 55 gallon drum.
Posted: Mon Mar 14, 2011 8:04 am
by Weston_Duyck
Finally got it, tranny is out but the TC got stuck on the motor. So I'm at a lost on how to get that thing off
Posted: Mon Mar 14, 2011 8:15 am
by mike-tracy
On the engine bellhousing, is a black plastic cover. Remove that and you can access the bolts holding the TC to the flex plate. Note since you pulled the TC and motor still connected, there's a chance you messed up the tranny's input seal. I'd highly recommend replacing that. I didn't once, and had to pull engine again. The tranny? Well it was a gusher, lol, till I replaced the seal.
Posted: Mon Mar 14, 2011 9:37 am
by Weston_Duyck
Shit. I should of thought of that, well hopefully nothing got to messed up.
