Need some assistance with starting.
Posted: Mon Mar 14, 2011 11:32 pm
by Tim bray
I have a 94 Legacy Subaru which started intermittently. Now it will not start at all. Replaced ignition switch and the actuator switch, and it still doesn't start. The #2 and the #4 relay have no power. I hot wired #4 to the battery and the car started, but I still do not know what the problem is. Does anyone have any ideas?
Re: Need some assistance with starting.
Posted: Tue Mar 15, 2011 3:27 pm
by cj91legss
Bad ignition wire from the switch to relay?
Posted: Tue Mar 15, 2011 5:00 pm
by Tim bray
does a 94 legacy have an ignition relay?
Posted: Tue Mar 15, 2011 8:08 pm
by cj91legss
there should be a relay, under the dashboard tucked way up above the ecu. It's really hard to get to it with the dash in, but very possible.
Posted: Sat Mar 19, 2011 5:52 pm
by Tim bray
After checking all the parts stores I have a5 to 7 day wait for the relay. Is this relay used anywhere else that I can go to the salvage yard and get one. I have a 17 year old driving a 3/4 ton dodge to school and it scares me to death.
Posted: Mon Mar 21, 2011 5:51 pm
All the first gen Legacies, 90-94 would have this same relay. I'm not sure if the newer Subaru ignition relays would have the same pin orientation for the relay, but if you've got a junkyard you can snoop around, you may find something.
Posted: Mon Mar 21, 2011 11:50 pm
by Tim bray
ok the relay is the brown connection next to the green one way under the dash on the driver side, but how do you get it to release. I've spent two hrs trying and have worn a permanent groove in my thumb.
Posted: Mon Mar 28, 2011 6:05 pm
There's going to be a clip that will release it. I've never had to deal with it, so maybe someone that has can show you a picture or give you a little more help.
Posted: Wed Mar 30, 2011 4:46 pm
by Tim bray
Between the weather here in South Dakota and being away for work I haven't had a chance to work on it but I am off until Tuesday starting tomorrow so I will tackle it then.
Posted: Tue Apr 05, 2011 6:20 pm
by Tim bray
Ok, I replaced the relay and still nothing. Anybody have some more ideas?
Posted: Thu Apr 07, 2011 5:52 pm
According to this diagram, you should have power at pins 2 & 6 of the ignition relay while cranking. I know you mentioned 2 & 4 above, but did you check 2 & 6.
http://www.surrealmirage.com/subaru/fil ... arting.jpg
If you don't have power at pin 2, then the ECU is not sending a signal out to trigger the relay.
