91 Ej22t / partout
Posted: Thu Mar 24, 2011 2:11 am
All parts are off a 91 Ej22t with 150k on it
Injector/ sensor harness-50 / this is off a 93/
Intake manifold w/ throttle body-50
2 exhaust manifolds, 50 each / 1 of these is a 93/
Turbo-75
Alternator and bracket- 30
Power steering pump- 40
Heads w/covers- 50
2 coolant pipes w/sensors-20 each
Stock coil pack- 20
Oil pan and pickup-30
Stock oil cooler- 20
2 water pumps-20 each
Timing gears and pulleys-50
Crank pulley- 20
Auto trans flywheel-20
Crank sensor-10
Cam sensor-10
Stock sets of head bolts- 10
All offers considered. Figure out your shipping from 59007
Cheers!!
Turbo-75
Heads w/covers- 50
Stock coil pack- 20
Crank pulley- 20
Crank sensor-10
Cam sensor-10
Cheers!!
