intake sensor bringing me down
Posted: Sun Mar 27, 2011 4:46 am
by LegyC-LegyDO
On a drive, I was splashing through puddles, having a good time; then later that night, as I go to restart my car, it begins to idle very strangely ... violently. Sputtering, gasping, and always eventually dying. At times it would idle for 10 min; others for 4 sec, or wouldn't even start.
Anyways I replaced the entire air intake, and there was light mud splattered half way up the main intake hose, (Past the filter!), the sensor just after the filter was also spattered, and lightly caked with mud, I assume this was the problem, as the car ran very normal again after the swap.
MAIN QUESTION: What is the best air intake I can get for the stock ej 2.2 n/a? I am leaning towards cobb cold air (modding so it takes air from above the grille), but I was just wondering if anyone had some better suggestions, I'm looking for anything that may add a little more hp and torque. Thanks
Rallye
Re: intake sensor bringing me down
Posted: Sun Mar 27, 2011 4:50 am
by kimokalihi
Custom snorkel FTW!
Posted: Sun Mar 27, 2011 5:06 am
by LegyC-LegyDO
Maybe, where would you recommend to locate the intake vent?
Posted: Sun Mar 27, 2011 6:06 am
by kimokalihi
What are you using it for? If you're going through creekbeds and stuff maybe a snorkel wouldn't be a bad idea but you have to make sure it's water tight. I'd run it through the stock hole but make your own piping and through the fender up the side of the A pillar.
Posted: Mon Mar 28, 2011 5:55 pm
Are you running the stock air box and and air filter? If so, I don't see how the MAF sensor (which is the sensor you mentioned) could have gotten muddy unless the entire air filter was destroyed.
If you're running an open pod style filter, I would not recommend that with the type of driving you're looking to do. At the very least, put the stock air box and fender snorkle back on. Like mentioned above, if you want to be crossing rivers, extend an air snorkel that comes out of the fender or hood to the roof line area so you don't suck in any water. You may need to seal the intake track up real good if this is your plan.
Posted: Tue Mar 29, 2011 1:15 am
by LegyC-LegyDO
Yes all stock and I know man, I couldn't believe the sensor was splattered and wet either, but it was I promise, I'll post pics in a few days. The best explanation that I could come up with was that after a solid three weeks of heavy rain, and a 5 mile rally on a pot holly road, all of which were filled with water and splashing up right where the intake is completely saturated the airfilter. There was some standing water in the filter box, and the filter was very, very wet and dirty.
The idle started really messing up the day after that rally, during which the car's motor was constantly working between 4000 and 7000 rpm, and making a pretty good climb. With the totally saturated filter, I think the car was pulling for air so hard that dirty water did make it past the airfilter, which had no holes or anything.
Is there a way to make the engine ignore that senor?
Posted: Tue Mar 29, 2011 7:39 am
by Danny-G
Something I did to cure the water in the filter box was drill extra drain holes in the bottom channel thing. So far, I've seen the metal under the filter box wet and thats it. I haven't opened the box recently or driven through any puddles. It also makes the intake a little louder but I don't mind that.
Posted: Tue Mar 29, 2011 5:16 pm
The car has to have the MAF sensor in order to know how much air is going into the engine. No way around it. I'd clean the maf up and replace the air filter, and see how things run. If you plan to continue the puddle splashing, then you probably need to modify the air inlet setup so it's not pulling in so much water.
Posted: Tue Mar 29, 2011 9:14 pm
by LegyC-LegyDO
Yeah, I was afraid that the sensor was required. Thanks for the tips, I'll drill a few extra holes in the cavity below the snorkle for now. I already replaced the entire intake on the car with another stock intake, and it runs great.
But still guys, what do you think about the cobb cold air intake, which would be pulling air from above the grille, I heard that they are great and add a little hp/torque to any motor, but I've also heard that isn't true.
Any idea how it would affect the ej 2.2. n/a?
Also it seems like that it a better intake spot anyways, higher and direct air entrance?
Any thoughts
Thanks again.
Posted: Wed Mar 30, 2011 5:24 pm
You'll have to tweak things to get it to fit. IMO, the cobb stuff is a little over priced, especially if you got to hack it up to make it fit. Personally, I'd just leave the stock airbox in there.
Regarding the water and such, how are your fender liners? Do you have them, and are they in good shape?
Posted: Wed Mar 30, 2011 7:06 pm
by LegyC-LegyDO
Fender liners! Damn, I completely forgot I tore those out last summer, good thinking, I'll slip those back on, that should keep the water out.
Thanks again
...thet're such a pain in the ass though
Posted: Thu Mar 31, 2011 5:51 pm
Yeah....if you put the fender lines back in, you should be fine.
