				Power Q's
				Posted: Wed Apr 20, 2011 1:10 am
				by Tommio RS
				Hi everyone!
Im just chucking this out there because i want to see what peoples idea's would be with this setup.
AEM FIC piggyback ECU
550CC yellowtops injectors
VF39
AWIC
TBE
EWG
JECS maf.... maybe?
Im thinking i could get to the ground like....
220-240WHP
240-260WTQ
Im i TOO high?
I really just wanna beat stock wrx's and sti's!
Any thoughts?
				Re: Power Q's
				Posted: Wed Apr 20, 2011 2:33 am
				by SILINC3R
				well if you beat stock STi's then you'll beat WRX's all day every day. im sure you can look at all the other builds and find what they made. sounds like a good setup though.
				Re: Power Q's
				Posted: Wed Apr 20, 2011 3:27 am
				by darkcrave
				from what im hearing thats about right, but with the EJ22's SOHC kills the power. Swaping to DOHC should get you another 20-40WHP with supporting mods? Jecs will be a must ( think is supports 18PSI) from what iv learned
				Re: Power Q's
				Posted: Wed Apr 20, 2011 3:33 am
				by 93forestpearl
				Fretting on numbers is foolish.  Dynos vary significantly between model, climate, and elevation.
That said, having the same turbo and injectors as an STi puts you at a significant disadvantage since the STi engine makes the EJ22T look stupid in terms of airflow, not to mention displacement.  Besides, you do not have full control of your engine management situation.
darkcrave wrote:from what im hearing thats about right, but with the EJ22's SOHC kills the power. Swaping to DOHC should get you another 20-40WHP with supporting mods? Jecs will be a must ( think is supports 18PSI) from what iv learned
The stock turbo (and most turbos people use here) kill power.  Swapping heads is not necessarily worth it unless you are going to run a turbo specific cam profile.
				Re: Power Q's
				Posted: Wed Apr 20, 2011 4:24 am
				by Tommio RS
				Hmmm.
In terms of ecu control i can control everything other than the 02 sensor. That said why would you want to control the factory o2 when i can just stick in a wide band o2 with the UEGO gauge with 1 wire cuz of the AEM FIC.
Asfar as heads go... Yes the DOHC would out flow the stockers.... THO Doesn't a slightly more restricked head increase torque? Not great for power but torque should be good. That just me thinkin out loud tho.
Displacement really should not be an issue. I have been in many a 2.0L wrx from 02-05 with a stage 2 cobb access port and it could kill a stage one 05-07 sti with cobb stuffs and thats a 2.5L. I think the wrx wins cuz of the smaller turbo=better off the line and boost response.
93forestpearl your very VERY right in what you say about dyno's numbers are all usless! Its all about your but dyno and how YOU feel about it.
Thoughts????
				Re: Power Q's
				Posted: Wed Apr 20, 2011 5:05 am
				by kimokalihi
				I'd say it's all about how you stand up to the cars you're going up against, if anything.
				Re: Power Q's
				Posted: Wed Apr 20, 2011 3:50 pm
				by 93forestpearl
				Piggybacks do not give you full control over tuning.  They give you a lot, but it is not the same ballpark as a standalone.
Smaller ports do not increase torque.  They just move the RPM band where the heads are efficient.  The EJ22T heads are pretty snappy down low, but this makes racing difficult since they fall off up top.  You have to short-shift the car to take advantage of what you have.  The re-ground cams from Delta do help significanly, granted your airflow supply (turbo) has enough breath to support them.  Besides, off the line response is only good for rallycross or racing up to 40 mph.
The DOHC heads with stock cams are a two steps forward, one step back situation.  Yes they flow more.  Quite a bit more.  However, your wideband will tell you that your AFR is higher than it really is, due to the not turbo happy cam profiles.  Several cars around here have been stuck at 300 whp with turbos that are capable of much more.  We only got 300 whp out of Derek's car with 28 psi out of a GT3782....
				Re: Power Q's
				Posted: Wed Apr 20, 2011 5:58 pm
				Dan has some very good comments about the engine management.
I think you're numbers are a little high.  200-220 AWHP is probably a little more realistic.  As mentioned, the actual number is really dependent on the dyno, and they can vary significantly.  Your best bet is to find out what type of power stock STi's & WRX's put down on the dyno you will be testing/using, and your numbers will likely fall somewhere in between that.
				Re: Power Q's
				Posted: Thu Apr 21, 2011 12:39 am
				by Tommio RS
				93forestpearl I never though about those heads in that way before. I never knew! Thanks for the great info!!!
I just might have to look into some heads maybe down the road.
Standalones are freaking great i am not going to lye about that. Tho im not really made of money soo thats when the piggyback comes into play. Ill see how it all runs with the piggy and if its not good then ill kick it up a notch.
				Re: Power Q's
				Posted: Fri Apr 22, 2011 2:58 am
				by 93forestpearl
				Wasn't saying you should change your setup.  Just keep it all in perspective.  Enjoy the car with what you have into it, even if STi's give you trouble.
				Re: Power Q's
				Posted: Sat Apr 23, 2011 12:48 am
				by Tommio RS
				Lol! Sti's will probably give me some problems BUT i hope i can out launch them.
Tho it should be fun as long as everything comes to together right.
				Re: Power Q's
				Posted: Sat Apr 23, 2011 5:05 am
				by 93forestpearl
				Out-launching them means having a drivetrian that can handle it.  An STi can take a 5k clutch side-step.  Can you?
				Re: Power Q's
				Posted: Sat Apr 23, 2011 8:48 am
				by kimokalihi
				How many times can you drop the clutch at 5K in an STI before the trans gives up?  Regularly?  I saw a guy blow his trans in his STI drag racing and this was 2005 so his STI couldn't have had many miles on it.
				Re: Power Q's
				Posted: Sat Apr 23, 2011 4:20 pm
				by evolutionmovement
				You know what can handle it?  Toyota R154.
				Re: Power Q's
				Posted: Sat Apr 23, 2011 6:43 pm
				by ericem
				kimokalihi wrote:How many times can you drop the clutch at 5K in an STI before the trans gives up?  Regularly?  I saw a guy blow his trans in his STI drag racing and this was 2005 so his STI couldn't have had many miles on it.
blow a tranny or break axles?
				Re: Power Q's
				Posted: Mon Apr 25, 2011 1:59 am
				by 93forestpearl
				^ This.  And by "blow his trans," what do you actually mean?
A STOCK 6mt is capable of putting a car into the 9's given enough power.  P&L seems to like it enough to use a stock 6 speed on their drag car running 9's with drag tires.  If that isn't a lot of shock-loading, I don't know what is.
Keep in mind, power capability of a transmission is directly proportional to the driver's level of fail.  We all know WRX transmissions can fail at stock power or handle 350whp for years.  Same principle applies to a 6mt.  It's just that not enough of them have failed in such a manner that we can deduce a failure point.
				Re: Power Q's
				Posted: Mon Apr 25, 2011 2:08 am
				by kimokalihi
				ericem wrote:kimokalihi wrote:How many times can you drop the clutch at 5K in an STI before the trans gives up?  Regularly?  I saw a guy blow his trans in his STI drag racing and this was 2005 so his STI couldn't have had many miles on it.
Don't know what the official diagnosis was but everyone was saying he blew his tranny.  I didn't know jack about subarus back then.  It was before I ever owned one.  Still had my 89 toyota 4x4.
