lets play name that noise!!!!!
Posted: Wed Apr 20, 2011 4:39 am
by lucas
http://www.youtube.com/watch?v=bUUzkSOyW58
car was making this noise. possible water pump dying? loose belt? bearing of sorts anyone take a stab
Re: lets play name that noise!!!!!
Posted: Wed Apr 20, 2011 5:32 pm
It might be a timing belt idler bearing.
What I'd suggest doing is removing the power steering/alternator belt & AC belt one at a time and eliminate those pieces as a possible source. The engine will be able to run without those belts hooked up so you can listen for the noise.
Posted: Wed Apr 20, 2011 7:36 pm
by lucas
sound advice thank you, i never would have thought of that
Posted: Thu Apr 21, 2011 4:17 am
by TurnNburn
I would suggest idler as well. Did this just start happenging? You didnt by chance just do a timing belt did you? Thats when one of my idlers failed. I know it wouldnt take long to rule out weather or not its the PS pump or the alterator, but how long could you run without the alternator attached? Until the battery died?
Posted: Thu Apr 21, 2011 8:03 am
by lucas
im pretty sure its the power steering, been leaking a small amount for a few years. Started the car the other day it warmed up making that noise then i drove 40 miles then it wasnt doing it so idk.
Posted: Thu Apr 21, 2011 6:05 pm
I had a PS pump go out before, and when I took the belt off the shaft of the PS pump did not turn freely and felt like there was metal on metal grinding. I was amazed it turned at all....hahaha
Posted: Thu Apr 21, 2011 7:35 pm
by lucas
how hard was that to change
Posted: Mon Apr 25, 2011 5:32 pm
The power steering pump? It was pretty easy to change out. There are just three bolts holding it to the engine, and then you have the two lines to remove.
Posted: Tue Apr 26, 2011 2:40 am
by lucas
cool. didnt look that hard just the car being so old things might have fused together.
