Replacing lateral link. WRX, Wagon OR GC8??
Posted: Sat Apr 23, 2011 7:40 am
by 253.Asmo
Ditto. Which years match the geometry and size of our cars? Looking to replace them with Godspeed units, thanks!
Matt
Re: Replacing lateral link. WRX, Wagon OR GC8??
Posted: Mon Apr 25, 2011 12:36 am
by mike-tracy
GC8 for sure is right, don't know for sure about the GD's.
Posted: Mon Apr 25, 2011 4:01 am
by 253.Asmo
Picked up a set for the wrx, we'll see. If it doesnt work, then GC8 stuff all around should do the trick.
Matt
Posted: Mon Apr 25, 2011 5:35 pm
WRX wagon links will work fine.
Posted: Wed Apr 27, 2011 7:57 am
by TurnNburn
Dont the WRX wagons have a slightly wider stance? Like 3mm on each side or something so they will bolt up fine but will have a small affect on alighnment ie. camber? Someones build thread i read a while ago said they had some that made thier car wider? Of course i cant remember who so i cant double check, but i was just throwing that out there.
Posted: Thu Apr 28, 2011 6:03 pm
The WRX sedan has a wider stance. The wagons are the same as our cars. I'm runing a set of Whiteline adjustable lat links for the WRX wagon on my car.
Scroll down a little bit and you'll see the ones I've got.
http://www.surrealmirage.com/subaru/swa ... suspension
