Welded tranny crossmember?
Posted: Tue May 03, 2011 6:08 am
by Grayguy
So I was thinking, why should I bother to buy poly bushings for my tranny crossmember when I could just weld the 3 pieces together as one solid piece. I'd still be using the group N tranny mount to connect the tranny to the, crossmember, and I could still drop the whole unit to be able to drop the tranny. Am I missing something here?
Re: Welded tranny crossmember?
Posted: Tue May 03, 2011 6:12 am
by ericem
Don't do that just get the $30 pink bushings and call it a day.
Posted: Tue May 03, 2011 6:18 am
by Grayguy
Why? What's the difference? From a technical stand point, it seems like it'd be better, maybe even stiffen the chassis slightly.
Posted: Tue May 03, 2011 8:51 pm
by ericem
From my standpoint poly bushings still absorb some noise also if you weld it I doubt the bolts will line up PERFECTLY. Whenever I bolt up the crossmember i need to flex each end slightly to get it to light up with the chassis bolts.
Posted: Tue May 03, 2011 8:57 pm
by n2x4
I agree, lining those holes up is always a PITA.
I think if you wanted to weld something, you could consider boxing in the transmission mount itself. There's a lot of play to be lost there.
Posted: Wed May 04, 2011 3:52 am
by 93forestpearl
Without a jig, you can be assured to not weld it up straight. Besides, the poly ones probably aren't even necessary. Mine probably weren't. I would worry more about the mounts themselves, among other things.
Posted: Wed May 04, 2011 4:34 am
by Grayguy
Like I said, I already have groupN mounts for the motor/ tranny, it was just a random idea I had. I'd weld It in the car...but l guess I will just leave it alone.
Posted: Fri May 20, 2011 7:46 am
by biggreen96
Interesting idea. I'm going to look into this. Boxing the trapezoid shaped mount that actually bolts to the trans seems like a interesting idea too. I'm going to play around under there this weekend...
