High temp wire braid/loom
Posted: Wed May 04, 2011 3:11 am
I'm looking for some type of sheath or protective wrap that will go around the wires that I am running to the oil temp sensor. They will pass very close to the exhaust manifold, and I'd like to try and make sure they are protected from the heat.
I don't know if there is braided steel stuff or something similar to what is used over the O2 sensor wire. Anyone have some suggestions?
Re: High temp wire braid/loom
Posted: Wed May 04, 2011 3:32 am
by 93forestpearl
http://www.delcity.net/store/Loom-&-Loo ... KgodkR4flg
Or something like this from DEI. I wish I knew where they got it from, because they get an arm and a leg for it.
http://www.designengineering.com/catego ... -tape-kits
Posted: Wed May 04, 2011 6:23 am
by AWD_addict
I'm using some DEI stuff:
http://www.designengineering.com/catego ... /cool-tube
It's expensive, but on the upside no melting yet. It makes the engine bay look like an Apollo mission too.
Posted: Wed May 04, 2011 6:20 pm
by n2x4
The cheap version is to take the heat wrap off of the power steering lines on a junk yard Subaru. Same stuff.
Posted: Wed May 04, 2011 6:24 pm
Thanks guys.
Yeah that shit is expensive!
Posted: Thu May 05, 2011 3:07 am
by 93forestpearl
The really cheap version is to wrap the wire in fiberglass and cover that with aluminum tape. Works the same.
Posted: Thu May 05, 2011 5:36 pm
Thanks Dan, I'll have to see how long of a shield I'll need and go from there.
Posted: Sun May 08, 2011 7:19 pm
by 93forestpearl
I forgot that Aeroquip makes a nice firesleeve.
http://www.aeroquip.cc/aeroquipracingfiresleeve.aspx
That site has great prices on all things related to fluid conveyance
Posted: Mon May 09, 2011 3:30 am
by 93forestpearl
Also, I just ordered some of this silicone tape, since I had to order a bunch of other fittings. Seems like it should make nice home-made heat shield.
http://www.aeroquip.cc/624-endtapesilic ... litem.aspx
Posted: Mon May 09, 2011 10:25 am
by IronMonkeyL255
Posted: Tue May 31, 2011 6:47 pm
Thanks guys for the additional info. I've been traveling the past several weeks and will try and get back on the car in June.
Posted: Thu Jun 02, 2011 12:43 am
by 93forestpearl
Josh, maybe you should tell them you want a life outside of work? lol
Because I have all the time in the world to work on my car. Sounds like your negotiating skills could use some work..............................
Posted: Tue Jun 07, 2011 5:54 pm
Well it hasn't all been work. I was in Montreal for a week on business then was in Portugal for a week and half for vacation, and just got back from California last weekend after attending my grandfather's funeral. It's just been a busy month or so. I don't have any travel plans for June........yet.
Posted: Mon Jun 27, 2011 4:59 pm
I think I'm going to end up going with this stuff:
http://www.designengineering.com/catego ... d-sleeving
I only need about 3 ft or so. The plan is to run the wiring in a standard wiring loom and put this stuff over the top of the loom. I'll probably zip tie the ends to keep it from moving around.
Posted: Mon Jun 27, 2011 5:02 pm
Those prices for loom is ridiculously cheap compared to going to the store. I'll probably buy some when my stock gets low. Thanks for sharing!
Posted: Sun Jul 31, 2011 12:17 am
Here are some pics of the sleeving I got. I'm probably going to pull it back out and trim a little bit and find some aluminized tape to wrap the end by the oil pan.
http://main.experiencetherave.com/subar ... eadwork/33
