White smoke??
Posted: Wed May 11, 2011 3:00 am
So I have a 93 legacy turbo ej22. I just did timing belt head gaskets oil pump,intake gaskets,plugs, wires, battery,rad., ect.ect.ect. It starts and runs just fine. Right when I start it I get a little white smoke. When I drive it around the parking lot it smokes like a siv.? It smells a little like fuel. It does not smell like coolant or oil, and there is not even a hind of blue smoke. The car did not smoke at all before the work was done. I read it could be a bad ecu ground,or cam sensor. Does that sound like it could be my issue?
Thank you in advance!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
