96 impreza tranny in 93 legacy?
Posted: Sun May 15, 2011 9:25 pm
by Weston_Duyck
So I am in need of a new transmission but since I have the budget of a kid still in high school I have been looking on craigslist for deals. The first one I bought crapped out 2 weeks after I swapped it in so I am a little skeptical now but still trying. Anyway I found one out of a 96 AWD 2.2l auto impreza which is the same as my 93 legacy. Also comes with torque converter, rear driveline and rear diff(which I take it those won't work but I don't need them replaced anyway). The CL post said it had 45,000 on a professional rebuild so I supposed it sounds good but doesn't mean it is. So if you guys could get back to me with any info or opinions that would be great. Thanks
Re: 96 impreza tranny in 93 legacy?
Posted: Sun May 15, 2011 9:28 pm
by cj91legss
if the ratio is different you will need a matching diff for the trans and the diff will fit
Posted: Sun May 15, 2011 9:57 pm
by Weston_Duyck
So to even make that work I would have to find a front diff with the impreza ratio
Posted: Sun May 15, 2011 10:04 pm
by Weston_Duyck
And sorry it's a 99 impreza not 96
Posted: Sun May 15, 2011 11:55 pm
by subydaddy
Either get the matching front diff or move a few parts from the blown legacy transmission to the newer transmission.
The trans in my 92 legacy is from a 95 impreza that had 95k miles on it. It's been a year and a half on revtronix stage 2 and still holding up.
I have air tools but the only special tool I had to locate to do the swap was a large socket, 33 or 35 mm. I don't remember, just that it was BIG.
Posted: Mon May 16, 2011 12:38 am
by Weston_Duyck
What parts could I take out of the blown one to make it work?
Posted: Mon May 16, 2011 12:39 am
by MikeyMeyagi
that wont work. the 99 is different electrically then 98 down.
Posted: Mon May 16, 2011 12:53 am
by cj91legss
even the casting is different, the 99+ transmission are stronger. I think all the bearing sizes are different as well, but it will still bolt up to your engine.
Posted: Mon May 16, 2011 1:48 am
by Weston_Duyck
Damn alright. Well thanks for the info
Posted: Mon May 16, 2011 4:33 am
by subydaddy
Damn, missed it by a year. Keep searching craigslist, you'll find something to get that suby back on the road.
