Replacing bolts on Turbo to Down Pipe
Posted: Mon May 16, 2011 3:14 am
Ok guys, Im tryin to get my new Tsudo uncatted 3" divorced DP installed and Im experiencing some frustration due to extremely corroded fasteners. Ive done a good bit of reading here and on the net and it would seem that the recommended combination is stainless flange nuts with non-stainless bolts. What have you guys used?
So far Ive managed to bork the two studs at the top of the turbo flange (the ones with a nut on both sides) and Ive completely destroyed a bolt to one side closest to the top stud near the waste gate by torquing it till it snapped. I think Im screwed so let me down gently. After such luck Ive left the rest alone for now.
Aside from general emotional support and commiseration Im hoping for the following information:
What can I use to replace the studs and where could I go to get it on the cheap? I was thinking of just cutting a piece of allthread but Im not sure how well that will hold up to the heat?
If I torch that snapped piece can I get it out with some sweat equity or will I need to invest in a good extractor to remove it?
I only started this myself because the exhaust shops wont touch it since it involved replacement of the stock DP with an uncatted piece. I only have basic tools and not much funding (still trying to raise the cash for the muffler and the rest of the piping) so Im looking for working DIY solutions.
As always, any and all advice, suggestions and practiced solutions are very much appreciated.
Ben
Ben
