Black goo sealant found on tail lights....where to get some
Posted: Mon Jun 27, 2011 6:51 pm
There is a black sealant that's found on the tail lights to seal them against the car body. Does anybody know what that stuff is, or where to find it new? It's also used to seal up the AC evaporator box, and I'd like to put some on the joints before I put the new box in.
Re: Black goo sealant found on tail lights....where to get s
Posted: Mon Jun 27, 2011 8:32 pm
by Danny-G
I think I've heard it called elephant poop. Or theres something really similar with that name.
Posted: Mon Jun 27, 2011 9:23 pm
Ok, I'll search online and see if I can come up with a name. I think it'd be funny to walk into the autoparts store and ask for some elephant poop.
Me: "Excuse me sir, do you have any elephant poop?"
Autoparts store Jockey: *Blank Stair* "What...?"
Hahaha :lol:
Posted: Mon Jun 27, 2011 10:45 pm
by evolutionmovement
I would try an auto body supply place. I don't know what you call that stuff, but that's where I got seam sealer and metal bonding epoxy. If you have a place like the guys near me, they'd be able to figure out what you're talking about by the description.
Posted: Mon Jun 27, 2011 10:54 pm
by Deride
It's just strip caulk and 3m and other places make it. Go to an auto body supply place like he said and they should have it. It's not nearly as messy/stringy as the Subaru stuff either :P
Posted: Tue Jun 28, 2011 6:21 pm
Talked to a buddy who does body work last night, he confirmed it's just strip caulk and has some I can use :)
Posted: Tue Apr 17, 2012 7:42 pm
by 94subarulegacy
It is called butyl tape.
Posted: Thu Apr 19, 2012 3:08 am
by magicmike
94subarulegacy wrote:It is called butyl tape.
ding ding ding. we have a winner
Posted: Thu Apr 19, 2012 6:03 pm
Thanks guys.
Posted: Sat Apr 21, 2012 2:41 pm
by magicmike
A side note. When I was installing we used two types. The butyl tape is very "hard" for lack of a better word and less pliable if you are trying to form it into a hole or something. We used 3M Strip-Calk (Part No: 051135-08578) for 99% of the stuff we did when going through exposed sheet metal etc. Its 10 times easier to work with. Also, this is the stuff used to hold the plastic vapor barriers on door panels. If cost was a factor or availability I'd use either personally to seal off tail lights :)
Posted: Sun Apr 22, 2012 10:28 pm
Thanks for the clarification. I used the 3M strip caulk for ac evap box. It worked and was gooey
Posted: Mon Apr 23, 2012 2:00 am
Butyl tape came to mind, but the stuff I've used for sealing outdoor connections on cell antennas is definitely too hard to use to seal headlights unless you maybe heated it up first. In the cold, it's resistant to even sticking to itself. We'd warm it with our hands to get it to form to the connector, then we'd wrap it in electrical tape.
