Coolant weirdness, thoughts needed :S
Posted: Wed Jun 29, 2011 10:06 pm
Ok, so i want to throw this out to the community.
I literally just changed my head gaskets about 4 months ago, and now in my metal overflow tank I've got some weird brown/gray goop... which leads me to wonder what is wrong with my current coolant setup in that i could have possibly blown another headgasket.
ok so symptoms:
I drained my coolant and it was pretty gross, def not green until after the liquids settled in a large container on top of each other. my metal tank and overflow tank were both covered in the stuff. I purchased a new radiator (KoYo) after fixing the headgasketsm so there wouldn't be any goop in that but there could be some in my heater-core correct? I also just replaced my thermostat during this whole ordeal.
Car is so far not getting hot in the readout on the cluster... constantly sits right before half like always.
But basically, I've got goop..
Any ideas? maybe i messed up on a line somewhere and am merging coolant and oil (hope not) but it just has me wondering. brand new metal headgaskets should not blow this fask on a mere 13lbs of boost.
Please post up your thoughts, i'd love to hear what you think.
thanks,
ok so symptoms:
thanks,
