That would be sweet if I can get that update thanks man
So I messed with evoscan for like 5 min tonight, I'll play around with it more tommorow. But I couldn't acually get it to read anything. Like what am I supposed to plug in for the specs? I just hit Subaru and the first cable option. It said it was all loaded up and good but how do I get it to read the data?
engine tunning options? / data loging, Im Lost
Re: engine tunning options? / data loging, Im Lost
93 legacy l
to much to list....
to much to list....
You have to select which ECU you have or it won't work. I chose the WRX EJ20G one because that's the ECU I'm using and it doesn't work on most of the others.
I can email you the update. PM me your email.
