Fixed!!! N/A no go. just replaced HGs
Posted: Tue Jul 12, 2011 10:12 am
Ok, so just replaced HG on my leggy, and now it alternates between a no spark condition which comes and goes, and running great for a few minutes and then shutting off. I noticed today while sitting in the drivers seat looking at the instrument panel that the temp was steady right in the middle, then when it shut off the temp spiked up to the top. This all happened at the same time, immediately when it started to die, the temp reading spiked. this all happened within about 1/2 second. literally. The no spark condition I think is a grounding issue, because all i have to do to fix it is wiggle the wiring harness a bit and it starts right up. Its still overheating, but i haven't really had a chance to burp it properly due to the don't wanna keep running bullshit. Any ideas? i need the car to go to work on wed, my normal carpool driver is on vacation and my wife needs her car.
Fixed!!
turns out I forgot to tighten up that little ground wire on the main engine harness that goes to the intake manifold. Felt really stupid when I noticed that it was loose. Spent 3 effn days checking every connection but that one. hopefully Others can learn from my FAIL.
Fixed!!
