D.I.Y Sedan trunk release lever.
Posted: Thu Jul 21, 2011 6:38 am
I've noticed how many of these sedans have broken trunk release levers. Heres how to get a new one from a wagon.
Items needed.
-Wagon gas flap release lever.
-Smaller round file.
-Saw or something to cut the plastic.
-Average sized flat file.
-Paint that closely matches you're interior color. (note, the paint isn't really required.)
-Something to hold the wagon gas flap lever when you cut it.
Step 1.
Get all the required parts.
Step 2.
Put the lever in a vice as seen below.
Step 3.
Cut the lever as seen below, make sure to end the cut before it gets the side with the opening for the release arm thingy.
Step 4.
Re-position the lever in the vice as seen below.
Step 5.
Cut the lever again as seen below. Expect the now trunk release lever to fall after finishing this cut.
Step 6.
Take the flat file and smooth the longer edge out along with the shorter edge. Use the round file in the corner to retain a factory look.
Step 7.
If you're not painting it, go take the old broken trunk release lever off and put this one on and enjoy you're "brand new" trunk release lever!
Step 8.
If you're painting it, sand it lightly with the flat file, hang it or put it on a table to paint it, then spray the paint in light coats untill you have the whole piece coated evenly. Then re-coat if you feel the need to and, also if you feel the need to, clear coat it. I don't have pictures of the painting process but I think you can figure that out.
Step 9.
After letting you're painted trunk release lever dry over night, go to you're car, remove the broken one and after making sure the paint is dry install the "brand new" trunk release lever and enjoy it!
If anyone has any question feel free to ask.
Side note, this is my first D.I.Y write up so I know its probably not perfect. Hope this helps many sedan owners like it did me once I figured it out.
Items needed.
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
Step 6.
Step 7.
Step 8.
Step 9.
