Altitude question.
Posted: Thu Jul 21, 2011 5:02 pm
by lucas
Running bout 16 in hg at 3500 feet. Normal?
Re: Altitude question.
Posted: Fri Jul 22, 2011 12:07 am
I'm assuming that is your vacuum reading at idle....correct?
Based on this chart
http://www.engineeringtoolbox.com/air-a ... d_462.html
There's a 3.6 in HG difference in pressure between sea level and 3,500 ft. Since you want between 19-20 in HG vacuum at idle, your reading of 16 in HG is good.
Posted: Wed Jul 27, 2011 4:23 am
by farfrumwork
My Vacuum at ilde was ~14inHG here at 5500' ASL (perfectly normal). Now with delta cams it runs 10-11inHG at idle (a bit low).
