O2 Sensor Relocate issues?
Posted: Sat Jul 30, 2011 9:31 pm
Hi All, I have a 94 SS that I am fixing up. I picked up an M2 WRX turbo back exhaust with cat the other day for 180$ (Thanks Craigslist). I have been comparing and reading through the post and I have a question. I did a search but no clear answer
The stock ej22t has the O2 sensor right behind the turbo. The aftermarket WRX exhaust has it after the cat in the midpipe. Normally if the O2 bungs didn't line up I would just extend wiring and call it good.
However since I would be moving the O2 sensor from before the cat to after the cat, is there any impact to the O2 sensor? Should I just get another O2 sensor bung installed and cap the existing?
Thanks for the input, alot of good info on this forum.
