Good deal on these fuel injectors?
Would i be able to use them?
http://cgi.ebay.com/ebaymotors/HKS-740c ... ccessories
Good Deal?
Re: Good Deal?
I'm not sure what set of fuel rails they will fit, but there's likely one that would work. More importantly, what engine management are you planning to use to control these? You won't be able to use these with the stock setup or possibly even a piggy back setup.
How much power you planning to make? These may be way overkill for what you're wanting.
Re: Good Deal?
Right now Im rob tune 550.
sometime in 2012 I would like to EJ22 DOHC swap EWG GT30 looking for around 400 Wheel HP
Im not sure what size injectors i will need but i do want room to grow while staying to a budget
