Timing belt help
Posted: Sun Aug 21, 2011 1:39 pm
by 1-3-2-4
Hopefully someone here will know this is for a Ej25 but I have an issue with the belt tensioner I think.. It's brand new btw.. what happens is when I set it to 29 ft-lb like the FSM says it no longer pivots up and down.. And at least that I can remember when I did my TB on my ej22 it would still pivot up and down when the bolt is tightened down..
I can't be missing any hardware since it's just the pullet bolt and the sleeve..
Here is a video if it's unclear.
http://www.youtube.com/watch?v=bbxjBAo-XSs
Re: Timing be;t help
Posted: Sun Aug 21, 2011 6:29 pm
Sounds like you don't have the collared piece in the circle. You can kind of see the back in this pic.
http://main.experiencetherave.com/subar ... P_2717.JPG
Posted: Sun Aug 21, 2011 6:34 pm
by 1-3-2-4
It was.. long story short I had to swap the sleeve and bolt from the old one (glad I saved it) and it worked fine.
Here is the pictures
http://forums.nasioc.com/forums/showthr ... ?t=2229987
