tranmission swapping
Posted: Sat Sep 03, 2011 8:38 am
by proace111
hey guys i have a jdm 92 legacy rs gt , but my gearbox (had a manual conversion so i dont know the code) thas been raped to the days , at the local wreakers theres a gearbox out of a 92 vz type r legacy (trans code TY752VD2AA) and im wondering if it wil bolt straight in and run without any hassels if anyone no's ,that would amassive help cheers
Re: tranmission swapping - SPD Transmission chart rallispec
Posted: Sun Sep 04, 2011 8:27 pm
by wtdash
Hi,
According to the SPD Chart yours is probably a 4.11 FD ratio. You're sure the code is missing from your trans?
And I think you typo'd the '92 Type R: should it be a 'B' vs a 'D' = TY752VB2AA
Regardless, it should work...Only if the FD ratio is wrong - could be a 4.44 or 3.9 - will there be an issue. Check your rear diff. Should be labeled.
TD
Posted: Mon Sep 05, 2011 8:04 am
by proace111
yea the trans code is an automatic , the rear diff is 4.11 ratio.
cheers
