to strut, or to sway that is my question.
Posted: Wed Sep 07, 2011 11:21 pm
by antslegggy
theres actually a couple , but
to buy a sway bar, or a strut bar is the main question.
a part two to that is, ( I own a 91 leggy turbo ss) do the 91's have a rear sway?
reading alot of the forum, the sways seem to be the better option for what they deliver vs the strut bars.
If the 91's dont come with rear sways, i was thinking 20mm in the front and 20mm in the rear to stiffin everything up.
thoughts and information is welcomed,
thanks muchos
tapson.
Re: to strut, or to sway that is my question.
Posted: Thu Sep 08, 2011 2:43 am
by SILINC3R
Depends on what your thing to fix. Basically the sway keeps the tires in contact and the strut bars keep the top together. You can use top and.bottom for the most rigidity or just the bottoms and still have a little flex or mix and match to make the front or rear twist more for flicking or powering into corners. I bought my strut bars from eBay for no more 150 bucks and.they are a good set. Sways are from whiteline.
Posted: Fri Sep 09, 2011 3:22 am
Get an upgraded anti-sway bar. You'll see a far more improvement with it. Strut bars will be almost a nill noticable improvement.
BTW, your 91 SS does have a rear anti-sway bar, and is 18mm.
Posted: Fri Sep 09, 2011 5:28 pm
by antslegggy
thanks guys, exactly what i was looking for.
Posted: Sun Sep 18, 2011 8:43 pm
by Guttersmash
What strut bars fit on our legacies?
Posted: Mon Sep 19, 2011 5:52 pm
GC Impreza bars. The fronts are direct fit, the rears need a little pursuading.
Posted: Sat Oct 15, 2011 6:08 pm
by Mattheww044
what exactly needs done to get the rear to work Josh? just gotta muscle it around til it lines up or is something actually different?
Posted: Mon Oct 17, 2011 12:26 am
With mine I had to bend the braket slightly so I could fit it through the hole on the sedan. If you have the wagon, you may not have that issue. Mine was a cheaper ebay bar. If you get beefier ones, bending the bracket may not work.
Posted: Tue Oct 18, 2011 1:20 am
by Mattheww044
hmmm.... you mean the mount that holds it to the body or the part that is connected to the end link?
Posted: Tue Oct 18, 2011 6:00 pm
The part that connects to the strut brace bar.
Posted: Tue Oct 18, 2011 7:44 pm
by Mattheww044
Oh I'm sorry I thought u guys were talking about the sway bars. That's good to know anyways tho when I do get tower bars
