Rear 4.111 LSD (w/ JDM 4.111 trans) - how to tell what type?
Posted: Sun Nov 06, 2011 6:24 pm
Hey hey!
So, I just changed out Uncle Scotty's 5MT Cocktail for some Valvoline 75W90 limited slip gear oil (read up on some worrying posts about the USC and when cold I have been feeling the drop in lubrication). I had replaced my stock 5MT with a JDM 4.111 5MT + rear 4.111 LSD a couple years back and am wondering how I can tell what type of rear differential I have?
I believe this photo shows the fill and drain plugs on the rear face of my diff, which I still have to find tools to fit and remove... how do I tell if I've got a viscous coupling LSD or a clutch-based LSD back here? This is mainly so I can then figure out what gear oil I should refill with. I figure I should probably change its oil along with the trans oil so they are about the same age.
Here's my ghetto-fabulous Subaru Maintenance Dock as I could not completely drain the trans with the front on ramps and I could not physically reach the trans drain plug with the rear on ramps. Thought you guys might get a kick out of it:
