Power light flashing!! binding while turning
Posted: Fri Nov 11, 2011 5:06 am
by criticalm@ss
Help guys, I did research all I could find is some hankshake method.
It flashes 16 times when i start it and binds when i turn like a stutter.
Help!!!!
Duty C solenoid??
Re: Power light flashing!! binding while turning
Posted: Fri Nov 11, 2011 5:08 am
by criticalm@ss
1992 legacy L a/t.
Posted: Fri Nov 11, 2011 7:00 am
by Bheinen74
the 16 flashes means the tcu has a code. it could be any code
Binding in corners could be many things.
1. thing it could be is mismatched tires, tires not evenly sized to 1/16"
2. It could be wrong rear diff ratio for trans
3. it could be clutch packs failed in the rear output of the trans
4, it could be duty C
5 it could be combination of 1 or all of the above.
but if you get 16 flashes there is a code to get. read up on how to get code. goes like switch on , put in D, press manual button, key off, put in 3, key on, press manual, key off, select 2, key onm press mnaul etc etc etc...
Posted: Fri Nov 11, 2011 7:21 am
by criticalm@ss
so do the hank shake method??
thanks btw.
Can an obd1 reader tell me?
Posted: Fri Nov 11, 2011 7:10 pm
Follow the instructions on my site for pulling the TCU codes and report back on what you find.
www.surrealmirage.com/subaru/trans.html
Posted: Sat Nov 12, 2011 6:33 am
by criticalm@ss
Awesome brother, it worked had to press unlock button to get it out of park.
code 24 2 blinks followed by 4 quick ones.
Ok so I am at 246k do i need to do clutch plate while its open or just look for wear and replace solenoid?
Duty c right?
thanks.
Posted: Sun Nov 13, 2011 6:50 pm
What I would suggest is clearing the TCU codes by pulling fuse 14, (EGI/TCU) for an hour or so. Then check to see if the code comes back. It probably will, but it's a good idea to just double check.
Also, here's the diagnostic tests from the factory manual.
http://main.experiencetherave.com/subar ... _diag1.jpg
http://main.experiencetherave.com/subar ... _diag2.jpg
Before tearing into the trans, I'd make sure the wiring is good as well.
You can remove the rear tail housing where the duty c solenoid is located with the trans still in the car. If you're tearing into the trans, it probably wouldn't be a bad idea to check and probably replace the clutch plates.
Posted: Mon Nov 14, 2011 5:26 pm
by criticalm@ss
thanks buddy, i will be glad to ge tthis wagon driving the way it is suppose to be.
Posted: Tue Nov 15, 2011 8:21 pm
by criticalm@ss
i unplugged fuse 14 yestrerday, should I plug it back in before starting or after?
Posted: Wed Nov 16, 2011 9:55 pm
Plug it back in before starting.
Posted: Sat Nov 19, 2011 2:54 am
by criticalm@ss
ok thanks, i need to do this soon.
I came across a hood same color and couldnt pass it up.
Posted: Mon Dec 05, 2011 6:42 am
by criticalm@ss
Ok so I am getting ready to purchase the duty c solenoid from the dealer? suggestions?
And how much am I looking to dump on new clutch plates?
