Help! Gouged Right Side(passenger) Cam when I removed seal
Posted: Mon Nov 14, 2011 6:03 am
I really screwed up guys... I gouged up the Cam shaft when I removed the seal tonight. I used the self tapping screw method and scraped the shaft in two places when I pulled the seal out using Channel Lock pliers. The two spots are right where the seal would be in contact while spinning so I can only imagine how quickly the oil will begin to flow out again if i put everything back together without fixing this. UGH!! I'm so mad at myself right now!!!! This is the 2.2 SOHC in my wife's 96 Legacy AT AWD.
I will never use the Screw method again! And I'll be much more careful if I ever get to do this again!
I'm reaching out to all you folks for suggestions on fixing this problem. Please give any and all thoughts.
I've already thought of 3:
1) Replace cylinder head or rebuild it with new cam
2) Sand down the affected areas very gently with increasing numbered grit metal sandpaper( finishing with 800 grit or higher) until the gouges are gone. Problem with this is that now there'll be a slight flat spot which might cause the seal to leak also
3) Use an cam end sleeve that would cover the affected area and return it to smooth condition. Speedi Sleeve is one brand name I researched a bit. I'm not sure if they have one that will fit the 2.2 Subie heads but it's an option until it isn't.
Are there any other ideas? How have others solved this problem? Any issues with the three solutions I've come up with?
This is my wife's car you guys. She wants it back soon. Help me figure this out.
