92 turbo legacy rear sway endlink question
Posted: Tue Nov 15, 2011 9:59 pm
by sliverumble
Alright so Ive fitted a 22mm whiteline rear sway bar to my 92 legacy turbo. I made the needed mods because it was origially made for a wrx I think. Anyway its been working well but is now needing new endlinks. Whiteline claims they dont make the ones I need. Does anyone know what company makes rear endlinks that'll work. My legacy was made 4/92 so its right at the year cut off when they started using the C type links.
Please advise,
Grant
Re: 92 turbo legacy rear sway endlink question
Posted: Wed Nov 16, 2011 5:19 am
by jamal
I'm assuming you have the vertical pin through the lateral link style links?
they used to make endlinks for it and they were included with BSR17XZ, but I'm not sure those parts are available anymore. Who did you talk to at Whiteline?
Also there are quite a few other cars that use similar endlinks. Some hondas for example.
or you could just find some used lateral links with the C-style links and go that route.
Posted: Wed Nov 16, 2011 6:13 pm
by 92.Legacy.SS
just swap the lateral links in and then either use the stock end links or buy some from white line go to the junk yard and start looking lol
