99 rs flywheel on tleg clutch???
91legacyawdturbo
My clutch blew up not even sure if it's the clutch, Will a 2.5rs flywheel work on a tleg clutch????
2002 wrx sport wagon
91legacyawdturbo
Re: 99 rs flywheel on tleg clutch???
Bump anyone please only have a few days intown.
No. The Turbo cars have a pull type of clutch, while non-turbo cars have a traditional push clutch.
91legacyawdturbo
Even though it's a hydraulic clutch?
- quasi-mod-o
Hydraulic or cable doesn't matter. Like PhyrraM said, nonturbo Subarus use push-style clutches, while turbo Subarus (before 2006) use pull-style clutches. Therefore, you need to get a turbo flywheel. You can use a 2.0L WRX flywheel, so try to find one of those.
91legacyawdturbo
ok thank you guys, I found a wrx flywheel and clutch locally I'll go pick it up in the morning.
91legacyawdturbo
Yup the wrx flywheel has the same bolt
Pattern to the tleg flywheel clutches are interchangeable,
down side to my dilemma is I blew up my second gear.
