So this past weekend I bought a 92 legacy ss hole car (-the block) for a steal of 500 bucks with a 04 wrx trans set up rwd. The plan is to drop in a 96 ej22e (120000miles) and bolt on all the turbo stuff( turbo, new t oil pump and water pump, t heads and manifolds. Run the turbo set up on the car till it pops(testing). I have a 92 ej22e as well I will be building with t pistons and crank and rods to Supercharge as the real swap for the car. The blockless shell has right under 75000 on it and is perfect not one spot of rust so pumped to have the twins as I call them. This 92 and my 94 ss track moster with a ej22t/2.5i hybrid! My man cave is Awsome with the twins
http://m984.photobucket.com/albumview/a ... g.html?o=9
Pics 8 to 11 Are drift car
92 ss legacy drift car rwd
•94SS full cage 2.2 hybrid build with 04 2.5i heads,JIC coilovers,jdm 4pots,vlsd,jdm TD05 16g ,top mount IC,950 injectors,running ms3x em
•91ss ej22t 110k,rebuilt heads,new seals,delta220 cams,td04,wrx top mount,wrx flywheel,wrx trans
•92L drift project h6 rwd
