92 ss legacy drift car rwd
Posted: Sun Dec 25, 2011 11:07 pm
So this past weekend I bought a 92 legacy ss hole car (-the block) for a steal of 500 bucks with a 04 wrx trans set up rwd. The plan is to drop in a 96 ej22e (120000miles) and bolt on all the turbo stuff( turbo, new t oil pump and water pump, t heads and manifolds. Run the turbo set up on the car till it pops(testing). I have a 92 ej22e as well I will be building with t pistons and crank and rods to Supercharge as the real swap for the car. The blockless shell has right under 75000 on it
and is perfect not one spot of rust
so pumped to have the twins as I call them. This 92 and my 94 ss track moster with a ej22t/2.5i hybrid! My man cave is Awsome with the twins
http://m984.photobucket.com/albumview/a ... g.html?o=9
Pics 8 to 11 Are drift car
