Vw 5x100 wheels?
Vw 5x100 wheels?
Will newer vw oem 5x100 wheels fit on my 94 legacy. I haven't seen them yet but I will get pic tomorrow. There 17s . I'll get full measurements in the morning. But of the top of your head. Thanks . Oh and there free lol
1998 legacy l wagon
1988 ford ranger prerunner (my baby)
1998 legacy l wagon
Re: Vw 5x100 wheels?
yes they will
http://r-hgarage.com/ -CLICK ME
92 legacy ss 5spd white- track car
03 wrx wagon 5spd silver- DD
84 chevy k20 4spd 4x4 blue lifted on 35"- wheeler/heavy hauler
Sweeeet. Thanks. Ill keep y'all posted.
1998 legacy l wagon
1998 legacy l wagon
What's the offset on those VW wheels?
offset and center bore.
ah, good question? the tires on them are 215/40/17 and a 225.
if they dont fit ill flip them. there a good looking wheel
1998 legacy l wagon
1998 legacy l wagon
i think i saw a wagon in the seatle spoted thread with these, he mentioned they were vw.
1998 legacy l wagon
1998 legacy l wagon
Volkswagen 5x100 wheels have a 57.1mm center bore. Our cars have a 56.1mm center bore. I don't think you can get a centering ring that's only half a millimeter thick, so if you use VW wheels you'll have to go without hub-centering, and use lug-centering instead. I wouldn't do it myself, but one can get away with lug-centering if one carefully installs the wheel, torquing the lug nuts evenly and gradually with the wheels off the ground.
As for the offset -- VW offsets vary between +35mm and +40mm. Our stock wheel offset is +55mm if I remember correctly. Lower-offset wheels may cause the tires to rub the fenders (especially if the tires are wide) and put greater load on the wheel bearings. If you're willing to replace your wheel bearings more often, you might be able to roll the fenders to get more clearance if they rub.
great info vrg3. thanks. thats good to know
1998 legacy l wagon
1998 legacy l wagon
those arent factory vw wheels btw. they are borbet type-t. nice find, they arent a very common borbet wheel.
you need to get all matching size tires so you dont screw up center diff. looks like they need new tires anyways. you are very lucky to get those wheels though, im jealous.
thanks, ya the tires are shot, ill get a set in the spring. . i just needed somting for the summer, i had a bunch of yamaha motorcycle parts ive collected over ther years from working at a bike shop so im trading this guy, no money out of my pocket.
1998 legacy l wagon
1998 legacy l wagon
euroshark good call on the brand, i googled it. didnt see any on a subaru, they might not work but i can flip them and get and get a set of oem wrx wheels. i get them tonigth so well see what happens.
1998 legacy l wagon
1998 legacy l wagon
Got the wheels. The powdercoat in new never mounted. Two of them have 215/40/17 . Is that too big ? Im goin to test mount and see what's up.
1998 legacy l wagon
1998 legacy l wagon
No that's not too big. I'm using 225/45/17 and I've seen people use wider tires as well.
The other tire is a 225. And it look like a truck tire compared to my 185 on it now. Lol. Did the 225 rob power? Or is yours big power
1998 legacy l wagon
1998 legacy l wagon
one of the good things about working with a service department. so i got the 225 tires off and notice the inside of the wheel has a small flat spot like he hit a curb . hopfully the will balance. im in search for some tires now.
1998 legacy l wagon
1998 legacy l wagon
anybody in portland have any 215/40/17 just need 2
1998 legacy l wagon
1998 legacy l wagon
If you want hub rings any machine shop should be able to make them really easily.
Thats what I'm goin to do. My friends dad works at a machine shop. Vrg3 said a half mm. It won't cost me anything, it's worth a try. It has tapered lugnuts so I'm goin to mount them and do some measurements.
1998 legacy l wagon
1998 legacy l wagon
i will buy the rims if you want to sell them!!!
ok ill keep that in mind. i got a friend looking for a couple of tires for me, he works as a detail guy at toyota. you got first dibs if i want to sell them. i wanna see them on the car first.
1998 legacy l wagon
1998 legacy l wagon
sounds good
If you have access to a machine shop, you might ask them to actually mill out the bore on the wheels to a larger size so you could use more substantial centering rings.
Ya. That would be better than having such a thin ring. I'll look into it.
1998 legacy l wagon
1998 legacy l wagon
Good point, wasn't really thinking about how thin .5mm is, probably a good idea.
