Does anyone know if this intake will work for a 91 ss
Posted: Sat Jan 07, 2012 2:32 pm
by denver427
Wondering if this works as a coffee can delete intake mod
http://www.ebay.ca/itm/Autobahn88-Silic ... 887wt_1185
Autobahn88 Silicone Induction Intake Hose Pipe Subaru Legacy B4 BP5 BL5 EJ20
Re: Does anyone know if this intake will work for a 91 ss
Posted: Sun Jan 08, 2012 3:00 pm
by James614
Negative. For that much money you can get an apexi power intake (for 92-96 wrx) that fits perfectly though. It's a short-ram intake but it's possible to keep the airbox with it instead of using their cone filter. But if ALL you want is a coffee cup a homemade can is the way to go (intake sticky has everything you want to know).
I wanted a short-ram intake, so I got the apexi. It's kinda rice, but I love the noise and All of my other mods will look stock so I don't care.
Posted: Sat Mar 17, 2012 1:09 pm
by Thesubielover
Does the apexi fit the ej22t? I wouldnt mind getting one from there site.
Posted: Sat Mar 17, 2012 6:47 pm
by Subiman91ss
does the apexi fit the VF11 turbo? that autobahn88 is made for a TD04/TD05.
Posted: Sat Mar 17, 2012 6:53 pm
by James614
Yes it fits fine. There's one less nipple, so you have to tee together the canister purge and BCS lines.
Posted: Mon Mar 19, 2012 4:43 am
by Thesubielover
If you have one, do you have pics?
Posted: Thu Mar 22, 2012 3:56 am
by James614
I have one, I'll try to get some pics of mine tomorrow.
Posted: Thu Mar 22, 2012 7:20 pm
by Thesubielover
Sweet thanks man, I'm not sure what teeing the lines really entails so pictures would be most helpful. I looked on the apexi web site and they dont sell iut anymore on there. I guess I could get one from ebay. Hopefully its the right one.
Posted: Fri Mar 23, 2012 3:56 am
by James614
I got mine from Rallysportdirect.com. Search "Power Intake" and it'll be the one for V1/V2 WRX. It's usually on back-order but comes in within a couple of weeks of your order.
Unfortunately I don't have the stock boost control solenoid hooked up, I am using a manual boost controller which lacks the vacuum line going to the resonator. But on the stock BCS, this line is plugged into the bottom of the resonator. Now that I think about it, even on the stock setup you can just ditch this line all together and cap the nipple on the BCS; That's how my car was for 2 years before I put my MBC on. I forget what the line is used for, but it doesn't affect boost operation or fuel cut that I could observe.
