Clearing out the Garage, Engine Parts, EJ22T, EJ25D, EJ20G
Posted: Sat Jan 14, 2012 7:09 pm
by All_talk
Its time to clear out some stuff I don’t need. All parts are used. All prices are OBO, if they are out of line just say so. Local pick up is fine, will ship at buyer’s expense. All parts are in Thorp Washington but I drive to Coeur d’Alene Idaho weekly so pickup could be arranged there as well. Cash, Money Order or PayPal if you cover the 3%.
PM here or Email: bigfoot_man@hotmail.com
Group 1 – Left to Right, Top to Bottom
EJ25 Rods, 131.6mm Length x 52mm Crank – Big end honed 0.001” oversize. $15 set
EJ25D Rods, 131.6mm x 48mm – missing 4 nuts. $20 set
EJ22T Rods, 130.5mm x 52mm - $40 set
STi Rods, 130.5mm x 52mm – One has spun a bearing. $20 each (good ones), $60 set 1 Sold
EJ25D Injectors with rails, 270cc?? - $40 set
WRX Bypass Valve ’02-’04 - $10 SOLD
EJ20G Injectors (Grey Top), 440cc – with plastic caps, work well. $80 set SOLD
EJ20G Injectors (Grey Top), 440cc – W/O plastic caps, I never ran these, one wont click when tested. $5 each (good ones), $15 set 1 good injector SOLD
EJ25 Rods, 131.6mm x 52mm – Small end honed 0.001” oversize. $15 set
EJ22T Crank – Good shape, could use a polish, keyway is not perfect but serviceable. $25
STi Rods, 130.5mm x 52mm – good shape. $80 set
Group 2
EJ22T SOHC Heads (w/head bolts)– Ran well when pulled. $50 Set
EJ20G DOHC Heads (w/head bolts)– Left side good, right head has broken snapring groove on 1 lash adjuster bore, good cams. Left $40, Right $15, $55 Set Sold
Group 3
Turbo manifolds & up pipe (no crossover), No heat shields - $30 set
EJ20G Intake with TB & IAC (also have fuel rails, not shown)- $40
Group 4
EJ22T Intake with fuel rails, pipes and wiring harness - $30 Harness & fuel rails SOLD
Group 5 – Any Item $10
EJ22T Cam, Crank and Knock sensors (knock sensor has a crack but works fine)
Motor mounts, DOHC & SOHC cam pullies, Crank gear & pulley Full set of DOHC Pullies Sold
Group 6
EJ22 Oil pan – All three parts $10
Water pipes with sensors - $10 each
Group 7 – $Free, pick up only (or throw a little something at me to pack it, you pay shipping)
Plastic intake pipe, and both PCV "Y" tubes SOLD
Group 8 - $Free, pick up only (or throw a little something at me to pack it, you pay shipping)
Timing Covers SOLD
Thanks for looking
Gary
Re: Clearing out the Garage, Engine Parts, EJ22T, EJ25D, EJ2
Posted: Mon Jan 16, 2012 1:44 am
by crisco
could use a knock sensor; ill pm you
Posted: Mon Jan 16, 2012 6:32 pm
by Conrad1147
Do the 22T heads still have the cams?
Posted: Mon Jan 16, 2012 7:14 pm
by All_talk
Conrad1147, Yes, the EJ22T heads are complete with cams.
Gary
Posted: Mon Jan 16, 2012 7:44 pm
by Conrad1147
Awesome! they are dual port exhaust correct?
Posted: Mon Jan 16, 2012 7:57 pm
by All_talk
Yes, dual exhaust ports.
Gary
Posted: Tue Jan 17, 2012 10:41 pm
by speezly
how much to ship the crank and rods for the ej22t to 23464? i might even take the ej22t intake and cam and crank sensors along with them if shipping isnt too high
Posted: Wed Jan 18, 2012 5:42 am
by All_talk
speezly wrote:how much to ship the crank and rods for the ej22t to 23464? i might even take the ej22t intake and cam and crank sensors along with them if shipping isnt too high
I'll shoot you a PM with the shipping quote. MIght make me a day or two, work has gone crazy this week. :?
Gary
Posted: Wed Jan 18, 2012 7:49 pm
by cj91legss
So i wouldnt mind picking up the black DOHC cam gears and that 20G Intake manifold in the near future. when do you make trips to the tacoma area?
and those DOHC timing covers since they're free if we meet up or something...
Posted: Sat Jan 21, 2012 7:55 am
by All_talk
speezly, you have a PM.
Posted: Sat Jan 21, 2012 7:59 am
by All_talk
cj91legss wrote:So i wouldnt mind picking up the black DOHC cam gears and that 20G Intake manifold in the near future. when do you make trips to the tacoma area?
No trips planned to the Tacoma area any time soon. There is one in front of you for the manifold and the full set of DOHC gears, I'll let you know if the deal falls through.
Garyt
Posted: Wed Jan 25, 2012 12:53 am
by LGT Kirby
I am interested in the STI or SS rods (the good sets) and the SS crank as well. I will be making a trip this weekend to Eastern Washington for college stuff, and will be passing right through your area.
Hit me with a PM if you'd like to set something up.
Posted: Thu Jan 26, 2012 7:47 am
by suberdave
PM sent on the EJ22t engine Harness.
Posted: Sat Feb 04, 2012 3:51 am
by Mister Anderson
I received the DOHC heads the other day. They are exactly what Gary said they were. The packing was amazing, nothing was able to move. Thanks again Gary!
I thought he didn't have pay pal LOL
Posted: Sat Feb 04, 2012 10:28 am
by kleinkid
I need one working 440cc injector. I could take the plastic tip off the injector I am replacing and put it on yours, right?
Posted: Sat Feb 04, 2012 6:06 pm
by All_talk
kleinkid wrote:I need one working 440cc injector. I could take the plastic tip off the injector I am replacing and put it on yours, right?
I’ve done it, but it’s not easy, the caps get brittle and can break. I had the best luck using a heat gun to warm it up a bit and going easy at it, but I broke a few too. The injector will work without the cap but it might affect the spray pattern or atomization a little, probably only at idle or very low throttle positions. I believe some people here on the board have run them without the caps, you might try a search. If I were going to run without the caps I’d probably do all four to give the ECU a better shot at balancing the fuel trims just in case the cap made a difference.
Gary
Posted: Sat Feb 04, 2012 10:27 pm
by kleinkid
I will probably get one of those with out the cap. I am going to contact Witchhunter and see if I can send it to them for cleaning, repair. I will get back to you.
They can fix it. I will take your best looking injector that you know works. Shipping to 98277. PM me your payment info and I will send you some cashola.
