easiest way to get LSD for my 1993 22t Sedan?
Posted: Mon Jan 23, 2012 3:07 am
by crisco
Hey i have searched and googled etc, but i havent been able to find a good bit of info on the easiest way to figure out which LSD i can swap into my car. i guess the '93 didnt come with rear LSD, right? so i can find one from a '91 Legacy SS, or are there any other subarus that came with rear LSD that have the same final drive (3.9) and will swap in (same axles, etc)?
thanks!
Re: easiest way to get LSD for my 1993 22t Sedan?
Posted: Mon Jan 23, 2012 6:38 am
You don't need one with the same ratio if you're willing to do a little extra work. You can swap the viscous unit from any R160 LSD into your stock differential:
http://www.rs25.com/forums/f105/t99509- ... -vlsd.html
Posted: Mon Jan 23, 2012 9:52 pm
by wtdash
Hi,
In my reading the only 3.9 rear diff w/LSD and the same axles in the USA is from the '91 SS.
The SPDA Trans Chart shows JDM and newer US models w/3.90.
The chart shows the WRX as a FD ratio of 3.90, and it has LSD, but:
Rear diff ring & Pinion = 3.54, X 1.1 intermedate gear = 3.90
Front diff Ring & Pinion = 3.90
GL,
Td
Posted: Tue Jan 24, 2012 12:23 am
by Florin1
I will have a 5spd with lsd for sale sometime soon. I got a 6speed, and its just a matter of doing the swap.
Posted: Tue Jan 24, 2012 4:44 am
by crisco
thanks guys! this is great info. i will either look for a '91 or ... look for a '91. lol. Florin, let me know when yours is up and i may or may not still need one and/or want to pay for shipping but its good to know.
since im in the east. the beast from the east
