93 Legacy L FWD M/T 5speed shifting problems.
Posted: Wed Jan 25, 2012 6:26 am
by madlash93
my 93 legacy i bought about 2 years ago and it has around 98K Miles on it, it was really hard to shift then and i think its starting to get pretty bad. It does it in first, third, and fifth. (really bad in third)
i have a video some what showing the issue i'm having.
http://www.youtube.com/watch?v=XUucBFip9z0
i plan on replacing the fluid with Mobil1 Synthetic Gear Lubricant LS 75W-90. in a few months when i get the money i might just replace the transmission, can i get a nice 6 speed? If so what one.
Re: 93 Legacy L FWD M/T 5speed shifting problems.
Posted: Mon Jan 30, 2012 7:39 pm
Does the shifter feel sloppy? Have you looked under the car to see if the shift linkage bushings are there? It's possible that the bushings are shot/gone and trying to get everything lined up to shift is difficult.
Or is the problem, it just won't go into gear?
Posted: Mon Feb 06, 2012 2:27 am
by madlash93
well new trans fluid really helped a lot, but its still difficult. ill look into what you suggested legacy777. (although when i replaced the clutch a while back it looked fin, i didn't pay to much attention to it though.)
it will go into all the gears just fine, its just hard.
Posted: Mon Feb 06, 2012 7:04 pm
If you don't have much shifter slop and it's just difficult to get into gear, the problem is likely internal to the transmission. Unfortunately I really don't have a solution for you that doesn't involve tearing into the transmission. You can try different fluids. Some may help more than others, but it won't fix the problem completely.
Posted: Mon Feb 06, 2012 8:34 pm
by madlash93
and anyone got a hint on a 6 speed i can fit to an EJ22 N/A? also where can i get the turbo exhaust manifold, i plan on getting forget internals because i want to run around 10 PSI at least. (doing this in a few years, just want to get a list of parts now.)
thanks for your help @legacy777
