Idle speed question
Posted: Fri Mar 30, 2001 12:49 pm
I got my SPFI cleaned today (Legacy 93), after cleaning it i noticed
that when i start the engine(after reseting the ECU), the rpm's goes right
to 2000rpm and then (about 10 sec) goes down to 750-850rpm, This happens
when the engine is HOT. Before the cleaning, it was starting right over to
1000 rpm's and going down to 600-700 rpms immidietly.
Tommorow Morning i will pay attention to see what happen when the engine is
cold. Except that, the Engine is running GREAT between 800-7000rpm's
Is it Normal or maybe something wasn't done good in the cleaning process ??
Please Reply & Thanks in advance for any advice !
Itzik.
Make good on the promise you made at graduation to keep
in touch. Classmates.com has over 14 million registered
high school alumni--chances are you'll find your friends!
http://us.click.yahoo.com/03IJGA/DMUCAA ... /X7OVlB/TM
Itzik.
