Third Gear Gone -- now what
Posted: Thu Mar 29, 2012 1:26 am
The synchros were goign bad --- 2nd and 3rd ground --- 1,000 miles ago, I could barely get it to go into gear one day climbing a hill, then it worked fine after a fluid change.
This happened all at once while I was cruising in third gear down a windy paved road -- let off the throttle at about 3500 rpm and all hell broke loose. .
It completely smoothed it off
Now, I put it in third and rev up and it sounds just like I'm in neutral.
It all a real drag considering I just put in a new alternator, replaced injectors, custom fabed my 07 TMIC Y pipe to turbo, installed all new silicone hosing -- cut out the cat and installed a 2 1/2 magana flow .... sigh
I was just starting to have fun.
SHOULD I rebuild?
SHOULD I find used 5mt from a 91-94 ss
or
WHAT OTHER types of subaru tranny's will bolt in to the ej22T
IF i need to get a 4.11 diff, so be it.
I'd appreciate any advice
Im real bummed
SHOULD I rebuild?
or
Im real bummed
