Speaker harness plug question!
Posted: Sun Apr 08, 2012 9:13 pm
by logan9691
I need to know which wire is positive and which is negative or if it matters which is which. This is the plug that plugs into the front passenger speaker.
Re: Speaker harness plug question!
Posted: Sun Apr 08, 2012 10:34 pm
I'm not sure to tell you the truth since that doesn't match any of the wire colors in this diagram.
http://www.main.experiencetherave.com/s ... iodiag.jpg
What year did that plug come out of?
Posted: Mon Apr 09, 2012 8:47 pm
by BSOD2600
Could use an continuity tester to definitely find out which speaker pair it's associated to...
Posted: Thu Apr 19, 2012 3:05 am
by magicmike
plug it into the speaker and put a 12 volt battery accross the terminals. Which ever combination makes the speaker "pop" outward is the correct polarity for the color. i.e if it pops out with the batt + on the blue and Batt - on the gray then there ya go.
Posted: Thu Apr 19, 2012 5:58 pm
You can use a 9 volt battery too.....it may not pop out as much, but should still work.
Posted: Sat Apr 21, 2012 2:50 pm
by magicmike
yesh, I should have specified, doesn't need to be excatly 12 volts. I even think a AA batt will do the trick :)
