06 2.5i right headlight. With lights and wiring. Think 1 of the mounts is broken off $75
06 2.5i tail light no guts or wiring $40
Back view of lights
Assorted fuel rails can be used to put yellow sti side feed injectors in other assorted cars $20 per pair
95 impreza visors or dash air bag cover $15
Aluminum Top mount intercooler elbows (port them without having downtime on your car) $30
2sets of exhaust manifolds 1 set from turbo leg $50, 1set from ver1/2 sti with equal length style on drivers side lightly ported $75 (have ceramic coated factory pipe to go with for $40)
Ej20k fuel rail $40
2 ej22t/ ej20g throttle bodies complete $40 each
Brake master cylinder w/4ports, 1" $30
Coil pack for sohc 2.5 engines (99-04 I think) $30
Wrx aluminum coolant header tank $40
Door cards for 2 door impreza with crank windows from 95 $20
Cam & crank sensors for early legacy few available $50 ea
Engine harness from 91-94 turbo legacy $60
Complete turbo legacy intake manifold with harness, rails, injectors, tb, and iac $100
2003 wrx wagon struts set of 4 still in decent shape $75
Optima red top battery in great shape fully charged $100
Have a 3.90 Rear diff (VA1RBF-XF) and the male axles to fit it. In good shape. Taken out when car was switched to 4.11's. $150 + shipping
