"Coilover" conversion for stock strut/spring (height adjust)
Posted: Sat Apr 14, 2012 3:55 am
by ciper
I remember reading this a few years back but cannot figure out which forum it was on. It was a list of parts that you could use with the stock struts and tophats to get height adjustability.
There was a sleeve that clamped around the strut tube and a set of "universal" springs with different rates but at the proper length.
It may have been intended for first generation Imprezas and not specifically the Legacy.
Re: "Coilover" conversion for stock strut/spring (height adj
Posted: Sat Apr 14, 2012 6:30 am
by mike-tracy
Posted: Sat Apr 14, 2012 7:00 am
by ciper
Not exactly. What I had seen was that you keep everything original and just replace the spring. The strut is not changed other than a threaded sleave slid over the top.
It was like this
http://www.ground-control-store.com/pro ... I=85/CA=25 but less espensive.
Posted: Sat Apr 14, 2012 8:39 am
by kimokalihi
Basically the same thing all the honda kids do when they get tired of cutting their stock springs.
Posted: Sat Apr 14, 2012 9:09 am
by ciper
I plan to keep the stock ride height or even raise the car. This would be a cheap way to corner balance it.
Posted: Sat Apr 14, 2012 5:33 pm
by beatersubi
Ground control is about the least expensive 'kit' around. Circle track vendors, like
Day Motorsports, carry universal stuff thats a bit less expensive but it's up to you to figure out front strut tops and spring lengths/dia./rates.
Posted: Sun Apr 15, 2012 12:07 am
by jamal
I think you can find them on ebay. although the spring rates you actually end up with are a mystery. They probably only do 8" springs where you want a 10" spring until you get into 400+ lb/in rates.
